I installed it sunday and no worky
I press the test button and my power injection bulb does not illuminate nor does the pump spin. The other bulbs DO illuminate.
I double checked my connections, even reconnected. I have voltage from the map on the green as verified with my DVM.
I put the dvm to the power dist. box and lo and behold it has 12 volts on the neg. AND the positive once I turn the key to the on position. I disconnect everything, remove the power dist box from the column, have it dangling down, jiggle some things around i guess, power vanishes from the power dist box when key is in the on position. I then hit the test button, I hear the pump go, i see the green light illuminate, and i get 12 volts on the dvm from the power dist box.
I figure something jiggled wrong or something. So I take the box and remount it on the column and clean everything up thinking im gonna go for a test drive. Didnt happen, problem appeared again, only thing i did was move the thing back onto the column.
This time I disconnected the pump wires, disconnected the map wire, only wires connected are the grey wire from the bulb and the power wires to the power dist. box
with nothing else connected and key in the ON position I have power on both the positive and the negative.
It really sounds like a short within the power dist. box to me.
I sure hope im doing something stupidly wrong or im definately not going to be the happiest camper. Being cramped up under a dash for hours with a roll cage door beam in the way is no fun.
