Razor - ???
strikeeagle
On the hose that goes from the reservoir to the pump:
I have:
Brass hose end
Clamp
Hose
Reservoir
How do things go together?
Thanks?
(PS - I'm stupid)
:D
Put the little worm clamp over the hose first.
Then take off the tape so the braid can expand.
Put the brass collar over the end of the hose.
Get a little lubricant like silicon and wet the tip of the hose.
Put the hose with brass collar over the tip of the tank. It will require a little work, but will go on..
Once the hose is over the nipple, get the little worm clamp and put it to secure the hose to the nipple. I use a small flat screwdriver to work it under the brass collar.
The collar is optional. I put it there just for cosmetic reasons. And it keeps the frayed hose from becoming a hazard :)
Remember its plastic. lots of lube, and lots of patience.. Dont try to do it with the tank mounted in the car. Do it with the tank out of the car.
:D
