razor's alky kit
ponykiller
hello all
i'm thinking about razors alky kit, i'd like some feed back please..
1st, where to buy the methnol, how huch is it per gal, all so how much do you use when you race, and or drive the streets... if there's any thing i'm missing fell me in on it... thanks :confused:
I Installed A Alky Control From Razor
ponykiller said:
hello all
Even though meth is great,it's not the only liquid to use.
Go to [Alkycontrol.com] and read.IT'S ALL THERE!!
My kit works great in the TTA.
If you call and talk to Julio you will find the parts list begins to snowball.
Just installing the kit by itself is not enough.You will need a few more goodies to coak the ponies out to play.
It's a great kit. I have it on my GN 20psi of boost and no knock ever. Not even a .01. always 0.0. So you can mod the car up nice and not worry about knock. In April I bought 4 gallons of meth from the track and I just used the last of it this week. I'm out just about every weekend with the car somewhere. I don't beat on it allot but I make sure I use some alky every time I'm out! :) Easy to install with his directions as well. You'll be happy with it and the expensive, dangerous playing around with race gas days are done! :cool:
BUY IT BUY IT BUY IT I promise you WILL love it..... especially if your car is mostly a street car. As we speak i'm running 25 lbs :eek: of boost on 93 and Alky. I will NEVER buy race gas again. :cool:
YES YES YES i'm going to buy... i read up on it and i like what i see, and i'll like how it feels 0-60 in 3.8 sec? (is that possable?) thanks for your help :) :wink:
You can do way better than that.. :)
Need to dial the car in and good tires. No problem.
I just finished installing Razor's kit this week-end, it does take a little time, but nothing about the kit is hard to install, plus the instructions are well laid out, one thing I did do was to have two 1 1/8"x4 1/2"x1/8" pieces of mild steel to help support the pump off of the two bumper brackets under the car where the pump is suspended, I just did not like the pump hanging from those two bolts only. I took the car out Sunday to do a little test n tune to see how this kits works, and it does work, I have the ME with 18 and 24 degrees of timing, Of course before this I have always ran 110 octane in my car prior to this, so with my setting at 24 degree and 22lbs boost no knock at WOT, I did also pick up turbo tweaks alky chip, I will install some time soon and see how well I like it, will keep you all posted. As it stands I'm very well pleased
with kit and it does work well, best bang for the buck.
Ron
we have it on all my cars .. go threw maybe 1 1/2- 2 gals a week @ 27#s :eek: :cool:
I forgot too say that I get the Meth from my oil dist. cost is about 22.00 per 5 gal.
Ron
get it & you wont regret it
this is a friends car. He was on 100 octane with PAC, but we are getting him weened off the c16. Next 9 second pass will be faster & on 93 octane.
http://www.turbobuick.com/forums/showthread.php?t=195824
Only bad thing about the kit is that you will make so much more power safely that you will then need m/t dragradials as the street tires will go up in smoke :biggrin:
Great results on Richs car Wes...the car trap 138 and weighs how much? Must be making 700rwhp+ right?
lol
you know them slushboxes & v6's cant do that. Have you not learned anything from n2s? :eek: Gotta have the 6 speed. Yeah Rich is fast, but would be nothing without us ;)
PAC pimped his ride :biggrin:
