dsmith4994
- May 5, 2004
The following parts are located in Wallingford CT. :
some of the prices are negotiable
shipping not included in price,
Turbo, elbow and throttle body 300.00 obo
downpipe 50.00
up pipe mesh elbow piece 40.00
intake manifold bare 40.00
radiator 80.00
radiator shroud (2 pieces) 30.00
clutch fan 30.00
crossover pipe 40.00
coil 50.00
maf sensor 50.00
stock cam pushrods and lifters 30.00
valve covers 20.00
valve cover bolts 5.00
egr solenoid (goes on cover) 25.00
egr valve/cover (goes on intake) 20.00
air cleaner, filter & plastic tubing 20.00
AC compressor 50.00
AC lines 40.00
P.S. pump 40.0
Alternator 40.00
alternator/ AC bracket 30.00
14 bolt oil pan 40.00
oil pan bolts 5.00
fuel lines 15.00 each
fuel rail 20.00
fuel injector wiring 40.00
stock injectors 20.00
coil bracket 20.00
engine wiring harness 50.00
computer 50.00
timing chain and adjuster 10.00
engine lift hook 5.00
intake bolts 15.00
key switch and key 10.00
water pump pulley 5.00
crank pulley 5.00
starter 25.00
starter power cable 10.00
flywheel bolts 5.00
catalytic converter 50.00
The following are Pick-up Only parts:
turbo heads 50.00 pair
engine block bored 0.060 over
200r4 transmission with torque converter 400.00
single exhaust stock type 50.00
transmission lines 10.00
email me at dsmith4994@aol.com for pictures or any questions.
Items will be shipped US mail delivery so their shipping rates will be applicable. Trades of parts for parts are welcome.
downpipe 50.00
radiator 80.00
clutch fan 30.00
coil 50.00
maf sensor 50.00
valve covers 20.00
AC compressor 50.00
AC lines 40.00
P.S. pump 40.0
Alternator 40.00
oil pan bolts 5.00
fuel rail 20.00
coil bracket 20.00
computer 50.00
intake bolts 15.00
crank pulley 5.00
starter 25.00
flywheel bolts 5.00
