87 turbo buggy
- Jun 5, 2004
corrections
1. The vega converter was a good tirck, only it will not work on the 200R4 / 700R4 lock-up's. It will fit 60/70/83^ 125, 250, 275, 300, 325, 350, 375, 400, 425 Turbo-Hydra-Matics, although none of the Metric/lockups/ or the dual pitch converter transmissions. The same Converter can change it's stall ,
through a function of basic or theoretically torque increase, even on the same engine. The better the Volumetric efficiency, more horsepower/torque will occure, leading to higher stall speeds.
As for the worry of boost, of where or when...it can all be changed. A simple change of the A/R of the turbine, and or, compressor housings can be made. Even a wheel-trim impeller profile will raises or lower boost onset. All of each can be done when you understand the what/why.
Matt E.P.P.
Matt E.P.P.
