Reading DS file help..
streetknight
DCVING
If someone sends me a DS file to look at in an email or posts it. How do I open it to look at it. I'm using window's 98.
Save or drag and drop the file into the direct scan directory on your computer.
You can first drag it to the desktop if that makes it easier, or save it onto a floppy and then put it in the folder where your other direct scan runs are stored.
Search for files with the same .ext extension type to see where they are on your computer, ie. which folder, if you don't know.
Then you select that file name to load into the buffer when you run direct scan on your computer.
