I just got home from the track, and all night long I was getting knock retard readings on direct scan in 3rd gear. I was slowly working my way up with boost, and leaning it out. The knock retard would go to 1 then 2 then 1 then 0 then 2 then 0 it was doing something similar to this each pass, and usually when I crossed the line it would be at 0. I'm running 110 octane, 22* timing, 24-25 psi boost on a TA49, 57 lbs injectors, TT110 chip,and about 11.0 on the wideband. It kept going back to 0 during each run, so I never let off. I wanted to keep going higher with the boost, but I need to get this figured out first. Thanks Dave
