Rodney87GN
- Feb 1, 2004
Over the past month I noticed my oil pressure at idle has dropped to 5-6 psi hot (approx. 195 degrees). When I first got the car it used to be 10-12 psi hot. Then a few months later it went down to 8-10 psi hot. Now it's at 5-6 psi. I know 8-10 psi is pretty normal for these cars, but at 5 psi I'm thinking something is wrong (or about to go wrong).
Oil pressure does go up with rpm, and I am at 10psi per 1000 rpm but barely.
I used 15W-50 Mobil 1 the whole time. I do not want to "band aid" the problem by running a thicker oil. I've read that the timing cover and oil pump clearances can open up over time causing low oil pressure. I'm going to pull off the pump and check it out but what else can cause this? Worn bearings? Cam?
