Rear Axle Parts
TurboWh1
I tore into the rear end of my car today and and found some broken stuff. Before I go buy new I'd like to see if anybody has some items that i need laying around.
Stock axles with the splines in excelent condion and of course not bent:)
Center section and ring gear. 3.42
Ring gear can be seperate but preferable still mounted to the center section.
My differential is the G80 Eaton Posi-I can salvage the posi portion, just need the carrier, cross shaft and lock bolt.
I have a set of low mile axles if you are still looking
I think I have an extra set at house. I'm in Beavercreek. I'll look this afternoon and post back.
are you going to try to reuse the pinion gear? By the sounds of it, you're headed towards a gear whine condition. best to get someone's ring and pinion and try to setup with a good pattern.
I have a pair of stock axles from my 86. Taken out at 60k miles. Make me an offer. I'm in IL.
Thanks to all who replied. I have decided to go all new aftermarket as I feel it will probably be best for my application. I did purchase a new ring and pinion as well:)
