How a 1984 posi that I bought seperatly that does not have any yoke bolts or straps. What size is the bolts/threads and were there straps used or caps used. Also the posi spring must be week because you can turn one axle easy with about a 16" bar between the axle studs while holding the other. Should I do more than replace the spring.
