SignUp Now!You could always use the stock fill hole. I use a short piece of tubing wire tied to the nipple on the gear oil bottle putthe tube in teh hole and fill till it just runs out. Heat the oil first if its cool out thatll help the flow.
What I do.... And, I poke a hole in the bottom of the bottle, once it's up in place. drains much faster.![]()
But you might have some left...
I have a TA cover also, just filled it the other day. I set three bottles of 80/90w gear oil on the floor register and let the furnace heat them over night. It took all three. But, I am curious about over fill. I did add the posi additive first.
Ok, How do you fill the rear end oil? I have a TA Cover and the fill hole smack in the middle of the rear.. Do they make a certain funnel.. Also What wt oil??? Thanks Guys
If I had a brain I would be dangerous. I forgot about the stock oil fill hole.That is likely 1 qt too much. The stock 8.5" rear takes a smidge under 2 qts.
RemoveBeforeFlight
Man, it must be cold where you guys live with all this oil pre-heating!
