rear main seal
turbot990
A member since 05
who carries a rear main seal for a stage 2 o16 block is the small block chevy the same
hi lee hows it going block no is o16 off center just fired up my new 109 with the old fast system sounds pretty darn good cant wait to turn it loose do you odie would no for sure
seals
I have one early stage [o16] block that takes a buick rear seal. i get NAPA bbc rear seals . some times i run into a good deal on them at swap meets, good luck oc,
