decaturforlife
- Feb 21, 2007
Been doing lot of reading up on the rear main seal but still wonder if I should go the extra mile to make sure the seal is good. When the car is running oil will drip on the cross pipe and some how get on the fly wheel which will make a perfect line on the drive way. At first the car use to drip a bit of oil after I boost up and stop driving the car. I remember playing with oil pan gasket. After that I started to see the perfect straight line. I'm guess since I'm going to replace the oil pan gasket should replace the rear main. Basically what should I look for in the oil pan?
