rear planetary spline wear?
JDSfastGN
Ive never really had an issue with this, but noticed the wear on my own transmission when i recently had it apart as well as two cores that i tore down over the weekend. Is this common and is there a cause or fix for the issue? . One just had a groove which seems ok because there is a groove in the output shaft at the same point, but the other two were stuck on the output shaft and the splines are showing obvious wear on the planetary.
very common jd.I use new ones on all of my stage 1 and 2 builds.Istock new ones if anyones is interested,some people never look there.
Thanks guys, yeah I have replaced them a couple times in the past due to the wear but hadn't come across it in most of my builds. I ordered one from Michelle yesterday:cool:
