SignUp Now!(Excepting HR Parts & Stuff poly bushings / control arms, which are of a design that is likely far more resistant to "binding".)
From my observation, it's not strictly the arms themselves, but rather the "split" poly bushings that allow each half to "relax" independently. The arm design (very rigid and dureable) and fabrication is top quality. But for those on a tighter budget, the HR arms might be overkill for milder street/strip cars.RKHiPerformance said:Not flaming, but can you explain what is different about the HR arms that makes them more resistant to binding?
Thanks,
Rick
carrddine said:I notice some of you guys are in cali will any one of you be attending the bates nut farm car show on jun 4th???
No, actually the HR Parts bushing is not like the standard Energy-brand bushing (at least, not the Energy bushings I remember from a few years ago; have they re-designed it??). I use to have those on car, and took them off. The Energy design uses a polyurethane piece that looks similar to the OEM rubber, except it's poly.RKHiPerformance said:If I understand you correctly, the feature you describe in the HR arms can also be found in the Metco, Edelbrock, and Hotchkis control arms. I believe these manufacturers (and others) use an off-the-shelf Energy Suspension bushing. Thanks very much for the explanation.
