GregorE
Hi everybody!
From one day to another my cruise control doesn’t work anymore.
It used to work correctly till today.
I already checked the following things:
1. Cruise fuse 5A is fine.
2. multifunctional switch seems fine too, when ignition is on and I switch to ON I can hear a click from the unit in the engine bay.
3. switches under the dash haven’t been worked on, they are both released when the brake pedal is depressed.
What else and where should I check in addition? What are the most common reasons the cruise control stops working?
Thank you!
Greg
Thank you!
Greg
