Hey Mark......
Did Jack cotton sell your liquid IC for you? If so I'm probably the one who baught it. Also you may want to talk to Jack about that walbro pump. A single walbro isnt going to feed 83's through your stock lines.
Fly...
I Highly recommend Jack Cotton also. Jack is a consistently good guy to deal with. He is a little nuts though
. Evey time you talk to him about going faster he is going to try to sell you a F.A.S.T system and a 66 turbo! He will get you what you need for a good price and stear you the right way though.
HTH: Jason
p.s: My buddy Rodger Davis aka Nashty has been running mid to low 10's for the last 3 yrs. He runs caps only, stock crank and rods, weisco pistons. The only real money you got to put in the short block is caps. You dont need racing rods or crank or none of that stuff. If you really only want to go mid 11's and no faster then you dont need caps at all. Cotton ran high 10's for a long time on stock caps with studs. If you only plan on running the correct fuel for the amount of boost and arent going to get crazy with the timing then caps would be a waste on a mid 11 second motor. The thing your the most likely to have probs with on a new rebuilt motor is the cam, unless you go with a roller.
You dont have to drop tons of money in the heads either. Gasket matching and a little bowl work will be plenty. There are WAY too many guys running in or better than your goal range with no head work at all.
HTH: Jason
Fly...
HTH: Jason
HTH: Jason
