Well, I finally got my rebuild underway. I made my own jig to hold the trans in my engine stand, also a homemade pump puller that worked like a charm.
Anyway, I was having a problem with my third gear shift starting to flare and slip. So out the trans came for a little work. I'm planning on adding a billet forward drum and input shaft, dual feeding the direct clutches, and all usual rebuild stuff.
My preussure gauge was where showing lousy readings once the trans fluid begin to warm up. So I believe the pump is going south causing the rest of my problems. I found some light scoring on the pump cover and pocket (enough to catch a fingernail) Does this look like it would be the cause of my low pressure issues?
I'm amazed on how good everything else looks inside. Even the direct clutches only have some hot spots to show for the slipping they were doing. I figured they would be totally fried once I got in there. Can anyone identify what frictions are in here? Also, there appear to be several different thickness steels, some black some silver in the direct pack, what's up with this? Where the steels ride inside the direct drum has quite a few burrs on it, what is the best way to remidy this? I tried to show it in the pics.
So please take a look at everything and let me know what you think of what I found inside so far.
