Recommended TB TT SBC .
KWIKR 1
I'm a little confused on the type of 90mm TB I should be using for a TT SBC (LS1 , LS2 , LSX , Ford , ???). I plan on going with FAST or the new Holley EFI . will need IAC (will be street driven) and TPS , so should I be looking at a Ford type TB or other ? Looking for something that will plug and play with FAST XFI or the new Holley EFI . Thanks .
I use an accufab 90mm TB, TPS sensor from Precision which is a Ford style sensor with the wiring harness for XFI. I'm sure Hartline or Precision can get you the correct IAC to work with both.
Thanks . is that the Accufab F90 ? I was looking at that one . :)
Aftermarket efi will work w/ either TPS and IAC usually. The older Holley used GM sensors IIRC.
Buy American.....
