A few questions for you all before I reinstall this stock radio.
It appears the installer of the aftermarket radio did not butcher the stock harness. However, in the second picture below, the connector is missing a fourth wire (the wires are behind the connector, and aren't visible in the picture). I think I located the wire (a red wire that was elongated and connected to the new aftermarket harness), but I do not know how to plug it into the connector in picture 2. If you look closely at the second picture below, one of the four metal sleeves is missing (top left metal sleeve). Can I purchase this sleeve from a parts store?
In the last picture (the one showing the back for the radio), the area where the connector is inserted has a piece of wire that is sticking out. Is this supposed to be this way? The black connector in picture two is supposed to connect to the lower row on the back of the radio, but this protruding wire is in the way.
Any help is appreciated.
