626gn
- Feb 15, 2009
Looking for a Red Armstrong XP fuel pump.
SignUp Now!That's a valid question that's been hotly debated here for many, many years but I'm the wrong guy to answer your question because none of that matters to me. In my case, it's simply a matter of personal preference, that's all.What was so special about his pumps I am curious, because I’ve read where guys have said over the years they where just Walbro Pumps?
Thank You for the Answer to that.It was a Walbro pump. Shimmed high pass pressure bypass. Needed before the high psi Walbro came out
Are you looking for just the pumps or the whole kit? I have a reds double pumper setup on a hanger that I removed a couple months ago. Nothing wrong with them I just decided to upgrade the whole fuel system, lines, rails, regulator, etc.Looking for a Red Armstrong XP fuel pump.
There was something else different about them. I dont remember what Red said, but he had connections within Walbro. They flowed more than the walbro 340 and out of all the intank pumps available, they lasted thr longest. I installed a lot of Walbro 340s that would only last maybe a season. Some were bad out of the box. I have a set of Reds pumps he was working on that flow 400lph and have the same external dimensions as the 255lph.Shimmed high pressure relief I believe. Better options now
Rob your right on point.There was something else different about them. I dont remember what Red said, but he had connections within Walbro. They flowed more than the walbro 340 and out of all the intank pumps available, they lasted thr longest. I installed a lot of Walbro 340s that would only last maybe a season. Some were bad out of the box. I have a set of Reds pumps he was working on that flow 400lph and have the same external dimensions as the 255lph.
