Steve Wood
- Jul 18, 2001
Originally posted by bruce
, once you get to being ROMless, you can do about anything you want with the code.
Is that because your step mother is a wolf and no one jacks with you?
SignUp Now!Originally posted by bruce
Originally posted by ILBCNU6
I have recently spoke to Red A. (about another issue not the Raptor MAF) he explained basically how it works,(MAf) tune your fuel to .790 to .820 O2 volts at 17# boost, then crank up the boost and the fuel curve remains constant, it flows over 700 gps.
Originally posted by Steve Wood
It is somewhere in between...if you change injectors, you gonna have to get a new set of fuel curves...it works with the stock ecm and there is only so much room to store stuff in a 512 chip. It will be a lot cheaper than a full fledged dfi, I am sure. He has a lot of pricing margin to play with.
Originally posted by mycarsucks
I do think it's really cool that people keep making products for these cars. I have always wondered if chips like the new Red, and the extender did things with the tables that the rest of us know about or if its something else. I did a search and cant really see how the extender works...
More like a speed density system....
Originally posted by CPAKCP
I have placed my order - can't wait - set fuel pressure @ 17 lbs to desired O2 or EGT range - and let the system take over up to 30 lbs of boost -![]()
Hurry up Red!!!!
James
Originally posted by Mike Licht
The Ford MAF's converted for GN's were for sale many years ago, by me. They were Pro-M Mafs that used a circut that was devolped for Pro-M and bought by Pro-M, by, suprise, Bob Bailey when the electronics they designed would not work. We flogged this technology for a while but there was 3 problems:
Originally posted by stangbanger
On my car, the O2 numbers were virtually flat with Red's MAF, the entire run, when graphed on DS. No top of 3rd gear lean out. This benifit should save a lot of motors and help those who don't have the ability or patience and time to burn chip after chip correcting fuel curves. Also, the boost building on the line was dramatically improved due to the reduced restriction in the intake tract. Taking fuel pressure out of the tuning equation is another great benefit.
