red/green light question.
djj624
I just installed razors kit today. Excellent kit he really took the time to make this kit install perfect for the buicks everything matches right up and goes together perfectly. My question is the light is supposed to turn red then green. On the first run the light did as its supposed to, red then green. Went to shop adjusted for more boost went back out and im not seeing the red light anymore. It goes directly to green and stays there till off throttle. Any guesses?
A little pressure in the line not letting the switch reset. Not an issue. Green is a good sign. If you wait a while and it goes red then green, maybe a slight turn inward on the allen screw will increase tension on the switch. Not a biggie. It wont affect alky delivery into the engine.
You can call me tommorrow if you need clarification. Thanks for the thumbs up.
Cheers
