I have a reds 93 chip in my car and iam getting some knock at 3/4 to wot with a mix of 110 cam2 and 93 pump gas. I have my boost at 17psi and my fuel press at 43-44 psi with the vac line off. Sorry the batt in the scan tool is bad so i cant test it out.
what does every one run with this chip or should i use my joe L 93 chip with 20*. By the way does any one know the timing on the reds 93 chip it does not say on the chip
thanks guys
as long is i did not brake any thing to bad tonight i will do some more test after work, i think i broke the stall , trans , or bottom end of the motor tonight
thanks guys
