trick86
Solid Member
- Nov 9, 2009
For Sale: 86 T Type, factory color Medium Grey on 40/40 Grey Leather with Column shift. Purchased the car in 2003' and completed to what you see here in the pics....detailed to the tits. Lifted the body off the frame just high enough to replace body bushings and refinish everything in satin single stage black. Original engine has never been removed from the car and is still on its original head gaskets. This car is well sorted out, does not leak and is bullet proof reliable for multi-state cruising. This is the first Turbo Buick I ever owned and its time to let her go to a new home. I have nearly all the original parts to put it back to off the show room stock.... I will be putting the car back to stock appearing installing the following: chrome bumpers, bumper strips with white inserts, original 86 grill, markers and signal lamps, original sport mirrors, production trans pan and rear diff cover. Restoring the original T Type wheels and can install the buyers tire of preference. Original EQ radio and speakers going back in. Alpine alarm with auto start will remain in the car. I have enough paper work that goes with the car to start a small bon' fire... original owner service records, GM Canada documents, old registrations and all the $$$ I put into it... It all stacks about 6" tall and is presently in a divided bookkeeper folder.
Body- refinished base/clear in RM, color sanded, 9/10. SS mirrors, color key smooth bumpers and GN spoiler added (couldn't come to drilling the truck lid therefore the spoiler is simply adhered on and can be removed)
Interior-All original except headliner and visors, RJC billet ring, 9.9/10
Engine-numbers matching 109', 206/206 flat tappet and lifters from TA, comp valve spring, true roller chain, all new seals(front, rear, valve, ect), PTE SLIC, Aluminum rad, H&R poly mounts, SM ported 62mm TB, 3.5 Maf/Trans, Pete Tomka intake, 43.5 lb injectors, TA-60, Poston headers, TH 3" Stainless DP, Hooker cat back, Alky Control 93 tuned to 23 psi, Scanmaster and TT chip
Transmission- numbers match BRF refreshed with top quality clutches and frictions, billet servo, Art Car shift kit, TCS 2800 9/11 LU convertor, BRH trans cooler, energy poly mount with plate
Rear Diff-refreshed carrier, Dutchman stock replacement axles, new seals, bearings ect,
Brakes- all new Delco, s10 rear wheel cylinders
Suspension- Energy Poly front control arm bushings, complete Moog steering components up front, Energy body mounts with the GNX bushing, Hotchkis Upper and lower rear control arms, Eibach Pro kit springs, Bilstiens shocks
I built this car myself and will prepare it how ever the new owner wishes to receive it from stock to as is....send me parts and I can make that happen too. If you have any questions it's best to reach me direct at: trick86@live.ca Car is located in Kelowna BC, 2 hours north of the Oroville WA border, I will assist in transport to the WA border cross and am aligned with US brokers to streamline the whole operation if required. I can personally met with an enclosed trailer in Oroville WA or in Spokane WA come spring time.. $23 000 USD
Byron
Byron
