Relisting 86GN
Musthaveboost
1986 gn t-top car94,500 miles.anderson performance built motor (4,800 miles)billet main caps,arp hardware,nice cam,forged pistons,race ported irons with 1.77 ferras, harland rr ,ported lower,helmco upper, 62mm tbmease streatch IC 3inch pipesnew blet,hoses,front cover,warter pump, all the stuff .57lb inj, translator + Z06 maf,mease 4inch inlet pipe/k&N,pt67gtq turbo,atr 3inch downpipe, hooker catback,3200 real art carr convertor with l/u,new trans built for the power this week from gbody parts,cutom braded cooler lines and B&M cooler,4 core super size alluminum radiator,alumimun core support,hr motor mounts,stock gears freash posi rebuild, ta cover,s-10 cylinders,kirban soft shoes,long studs.1le upper bushings, south side lower,kirban snubber. HR rear bar setup(sweet)front has been converted to 12 1le brakes on caprice spindals, hotchkis control arms, 36mm hallow way bar with poly bushings,ss front frame braces, kyb shocks,GNX style 16' wheels with micky et street dr's like new,gnx vents,no emblems (stealth look)energy suspension body mounts with gnx bushings,walbro pump hotwired,new rear fillers, new fronts ready to go on (oems are warped not cracked)glass bumper for front (new not on yet )scanmaster, greddy profec b electronic boost control (fast spool )boost,oil pre, water,knock,fuel pressure gauges (3 a pillar/ console holder)interior is in great shape only drivers seat botton is worn, no broken pastics,concert sound II,pwr seat,windows,locks,tilt,cruise,rear defrost, pwr ant,pwer trunk release,lighted rear view.gn mats.paint is 4 years old cleans up great.Issues header panel has small crack new one ready to go on.front fillers warped new ones ready to go on.windows are slow(arnt they all ? )ac pressure switch leaks freion,C.has been driven in the rain but never the snow.Not rusted doors are 100% as are the rest of the panels.
Problems...Blown Head Gasket
Salvage title.
Greg, I'll give you a call later about when we can meet up to see it.
I've seen pics of this car, and its very nice...
Went to go look at this car yesterday, Very nice car. Lots of big dollar parts. Well worth it.
when the headgasket blew were you running straight water or 50/50mix coolant, also intrested in any trades?
I saw this car... its like an arrow. No rust whatso ever under the T tops... would make a great summer cruiser;)
