Relocating have some parts to sell
mygn86
Remnants of a SMC alcohol injection kit. It has the bottle with the (NO GOOD) pump inside, in car controller, nozzle and misc attaching hardware. $100
2 up pipes 1 is used stock w/ hole drilled for IAT sensor and 1 brand new never installed aluminum from TR Custom parts both come with couplings. Stock $25/ Aluminum $50
2 sets of used Injectors 1 set is 36# purchased new from Cotton's and used for 10K miles w/ Cotton's 93 Oct chip and 1 set is 50# ( never got to install them)10K miles since last cleaning comes with 2 chips 1ea Joe Lubrant 20* street and 1ea Jim Testa street. 36# $75/ 50# $100
Bowling Green Customs stretched, 23 rows, stock location intercooler w/ a Duttweiler neck. This all new construction not 2 stock inercoolers welded together. Comes with a damaged shroud (see pictures) and the intercooler fan got in to it damaged 3 of the rows. It has been welded, stress relieved and pressure checked, no leaks. Sorry no passenger side bracket/ use original on drivers side. If want to install this as is you will have to remove front sway bar. I was not told this when I bought it otherwise I would not have. I was attempting to make it work for me but changed directions went with a FM. $300
More pictures
More pictures
Forgot to specify I need the 50's not the 36's. Couldnt see where or how to edit my post.
If there is anyway to find out for sure I can take em. I'll try to do some research. I have a grand prix and low impedance won't work. This is for 6 working injectors right? What all is missing from ally kit? I think I want that as well. Progressive?
@ Boosted GP Grand Nationals are the same you have to modify the ECM to run low impedance injectors. But alas, someone had contacted me before you and has claimed them. If the deal falls though you are next. 50# injectors sold pending payment On the SMC kit as far as I know all you will need to do is replace the pump. It is not progressive it one of the first kits. Thanks for the intrest.
payment in the mail...happy turkey day.Raymond
