SignUp Now!If you have a FAST setup and the timing is off, can't you just change the reference angle so the timing as commanded by the FAST = timing as measured by a timing light? I didn't think there was a need to physically move the timing ring on the balancer.
John
I had found a picture last week that showed how to adjust the reluctor wheel if it was off position. If any of you know can you post the link. I think it was on Vortex Buicks but can't find it on the site as well.
Thanks,
Eric
it is true that there is sometimes a variation in the placement of the reluctor wheel on the balancer assembly---------with a F.A.S.T. this seems to be of little bother since you can use a timing light and set it to where you want it to be but it can be useful to know where true "0" is--------as for moving the wheel to make it correct i did an interesting test a few weeks ago-------checked a lot of good condition undamaged stock balancers and found them within a few degrees--------here's the real surprise--------we selected a single stock balancer and took several of the sensors---------we found that the timing of the sensors varied MORE than the balancers--------the sensors were all GM replacements and appeared to be in good shape--------most were within 3 to 4 degrees but worst in the batch was 11 degrees out-------can't remember if it was advanced or retarded---------makes you wonder what kind of total variation could actually occur between two stock cars if one had a worst case reluctor AND sensor and the other had a BEST case pair...............RC
