salvageV6
Daily Driver
- May 25, 2001
Check your battery voltage when this occurs, and if you are still using the factory fan delay relay get rid of it.
Sounds like what they added causes a spike into the fan delay relay triggering it, once.
Not the only thing that can make the fans run when they shouldn't through that relay.
A spike occurs on the whole electrical system when an inductive coil, such as in the window motors, trunk release solenoid, sunroof motor, power seats etc. is operated.
A weak battery or lower voltage will increase the effect.
If you really want to try some harder tests, which I doubt since you didn't try any simple voltage tests yet, you can.
1. Voltage check when the problem occurs at the battery.
2. Charge the battery fully and try it all again.
3. Remove the viper wire that operates the trunk and try the trunk release as factory wired with the delay relay.
4. Another test would be with the factory wiring NO viper alarm wire and a diode accross the switch, 1N4004 type, banded end of the diode to the brown wire on the connector, unbanded end to the black wire. Key on normal trunk release operation.
Obviously the simplest thing and perhaps the smartest thing to do is to remove the problematic fan delay relay.
