Remove power antenna lately, need parts to fix mine
PaulRV6
I have an 86 GN, just replaced the mast/cable but also found the brushes bad. Looking for a contactor assembly with wire harness. If you have a junk antenna that you want to get rid of that might work for the part I will consider buying.
Also, I have a guy with an antenna from an '81 ttype that he no longer wants but I am not sure if this uses the same brush assembly and wire connector. Can anyone confirm this?
paul
