removing input check valve
tttype
Any tips on removing the input shaft check valve ?
Tried expanding it like suggested in transgo non lock kit, but it just slid back into shaft.
There is a land that will only let it go so far. I just use an EasyOut and knock it down into it until it grabs and then pull it out with a pair of ViceGrips on the end of the EasyOut while slightly twisting to the left. Takes about 15 seconds.
Thanks for info GNeric
Transgo instructions are of little help.
Ended up making a hook for a slide hammer & pulling it out.
