I found a great source for these seals, most turbo buicks need these seals replaced by now, they cake and crack over time leading to leaks you cant detect but hear them, these two seals sit on each side of the throttle body shaft, and are about the size of a dime, GM wont sell you these seals alone, they want to sell you the whole Throttle body which cost about an arm and a leg from them i found a great source for these seals, and trust me guys they need to be replaced if your car has more than 30k miles on it, the seal model and size are as follow, all metric size.
10x17x5B, the B at the end is the model of the seal if dont mention it you will get the wrong ones, you can get them from this supplier which is located in VA.
http://www.harwal.com
Harwal Inc.
P O Box 363
72 Industrial Lane
Barre, VT 05641
Phone: (802)223-0197.
just thought i share with everyone.
they run about $7.00 dollars each and there is no need to do mickey mouse work with these they are correct size and perfect fit.
Harwal Inc.
P O Box 363
72 Industrial Lane
Barre, VT 05641
