Hello all. I have all the info on how to replace these bushings/bolts but I would like some more clarification on what this "tool" (that I have to make) looks like in real life. I seen the drawing of this "T-Bar tool example, from the directions from gnttype.org but it looks different than its described. Does anyone have or can take a pic of this tool (or draw a better pic of it) and post it so I can visually see what I need to build? I am attempting this in the next few days so any help is appreciated.
I will be using a 2 post lift with those 4 swing out arms. I have read on these boards of many people doing this project on jackstands and, essensially, being on your back. I have access to a two post lift (with the swing arm jack pads). I want to locate those pads on the frame without covering the body mount access holes. I need to know if lifting the body up off the frame(working one side at a time with one side hardware unbolted and the otherside loose) is not advised on such a lift due to the "delicate balance" that the car is sitting on the pads. Anyone have a way to do this job on a lift that is safe? Please reply. Any help is appreciated. Thanks
STEVE Z
