Reproduction GNX Bill of Material Help
X Ray
The GNX changed my life!
TurboBuick.Com Supporter!
I would like to reproduce the GNX BOM (Bill of Materials). This document shows all the parts used to convert the Grand National into the GNX. It has ASC part numbers, quantity of parts, description ……
I need a printer and paper to accuretly reproduces this document.
The paper is Green bar 14 7/8 wide and 1/8 inch spaced.
The dot matrix printer used Telidon font.
I have attached a picture to show you what I am looking to reproduce.
If anyone can help me get this going I would appreciate your help.
If it's any help, I have an old OkiData dot matrix 24 pin printer with the sound enclosure (they're really loud otherwise). Worked perfect last time I used it years ago. Been stored in heated/air conditioned building. Probably would need a new ribbon and dusted off, but otherwise perfect. Yours for the asking. Pick up only in central Ohio. Think I even have the cable for it too.
Let me know...
will this be for sale?
I plan on it ..... If I can make it the way I want....it look like it will take a little time to get things worked out...
The process has finally seeing some results...I picket up this printer today...I will now start the process getting it working and creating the correct format.
