lyonsd
- May 24, 2001
Do you mount a separate tank under the hood to hold the alcohol?
How is it injected? A WOT switch? Or a button in the cockpit? At a certain boost level? Or some other method?
Where is it injected? Into the upper plenum? Into the intake manifold ports?
How many runs can you get in on the typical setup?
What different ready-to-install kits are available? Which is the most popular? What are the typical costs?
Where do you buy the alcohol? How much is it?
How hard are they to install?
