SignUp Now!the ta-33c is about the only turbo you can go to. some call it a ta-49 but its really a ta33. how far can it go. probley 11. something
Built? What kinda of heads, what cam, what compression, what's done with the intake, what headers etc
The TA33 supports the same compressor wheel as the TA49 (T04E-60 trim).
The TA49 has a T3-76 Trim turbine wheel and I think the TA33 has the same wheel.
The ta49 would be a better choice probably. You would have to move the throttle body off the turbo and put it in the intercooler pipe path or on the front of the intake like the factory 86 setup.
The ta49 is more widely available, will definitely handle your proposed power goals and can be mounted in the stock hotair location if you want to (there are no hood clearance issues).
If the throttle body will be on the turbo still you can get larger hybrid turbos built ($$$$), but they must retain the carbon seal backing plate and carbon seal so oil is not sucked through the turbo seal into the intake.
Just remember with bigger cams and turbos come other combination changes (torque converter etc). I am not an expert on that subject and you can probably talk to dusty Bradford for advice in that area.
Anymore questions can be asked to me and I'll try to answer them. I really could care less where the turbo is and if your car has an intercooler on it.
Anyways have fun and good luck.
Jerry jr.
So far the guy that builds all of my dads engines is the one doing it hes said to be changing cam, forged pistons,forged rods and porting the heads and im going with a ported 87 intake since im swapping it over to IC. I can give you exact specs as soon as he finishes it and sends me the reciepts with all specs on it
Heads are ported stockers until i can get advice on some better ones, Cam not sure of at this moment the guy thats building the engine builds all my motors and when he is done he gives my the reciepts and specs on everything he just told me not to worry itll be fast enough if not we can always make it faster lol. Going to port the stock intake and not sure on headers right now. I was thinking of converting over to IC but got bashed on so hard on the forums i decided not to mention it anymore and just do it since i couldnt find any decent advice and a few ppl going off on me lol o well each to its ownbut as soon as i get the specs i will let you know all it consists of!
How would i go about moving the throttle body into the ic pipe path or for the better half leaving it hot air would i have to still move it? I def want to keep it in the HA location and mabey add custom piping to run intercooler in front but keep turbo in stock location. And i will most likely be adding alky if it stays hot air! Thanks for your help and advise
