1984 t-type
Murphy's Law
- Jul 11, 2010
Can I reuse the stock balancer bolt or is it TTY ?
Thanks !
Thanks !
SignUp Now!You can reuse it. I can't remember the torque spec but it's up there
I had to torque mine while the motor was in the car, without a lift. I used a pry bar on flexplate to lock the crank and on my back I was able to torque it to 140ft-lbs. Finally I wedged my body and used my legs to push the torque wrench to get it to 219ft-lbs. I don't remember it leaking any oil, but I did put sealant on it.It's reusable. 219 ft-lbs factory. You may or may not be able to put that much on it. Put thread sealant on it or it'll leak oil from the crank galley.
Where are you guys putting the sealant again ? Backside of the washer ?
Since the crank threads don't go into any oil passage, putting sealer on the threads will not stop any leak. Maybe you were referring to thread locker on the bolt? Don't forget the slinger or you probably will have a leak from the seal. The only way oil can leak from the bolt area is if the damper is too loose a fit on the crank snout. That' were sealer would help.
That is odd. I have never seen that on any engine I have ever built. I put sealer on the inside of the hub before I slide it on the crankshaft and make sure I put some in the key slot because that's where most of the oil migrates from. I don't put any on the crank snout because the hub will push the sealer into the crank case. I built an engine years ago without sealer and it showed signs of oil inside the crank pulley. It wasn't really that noticeable until the engine was taken apart for a rebuild. Since putting sealer on the hub I have never seen any signs of leakage.Maybe my car is odd, but my crank snout bolt hole is connected the galley that feeds the rod journals.
No sealant, no locktite, never have had a problem.
Get rid of the bulky stock Bolt go arp less torque and yes use arp eng lube.
