brake
I/ll jump in as I assembled the unit. It is a Lonnie Dyer electric brake. We will be checking the linkage adj. as it has an after market shifter. Also the rear brakes before dropping the pan. I talked to Lonnie but he has not had that problem. I am open to suggestions.
BTW, the brake holds as it should and all forward shifts are perfect. Just the intermitten hard to back up. Have not put a heavy load on the brake as everything is fresh. (eng and trans)
