Reverse Trans-go Shift Kit?
85monte
Hey guys quick question! I bought a used BRF valve body and was looking at it and it appears to have had the TRANS-GO
HD2 SHIFT KIT installed. I have the instructions for this kit and it doesnt seem anyone drilled the valve body just the seperator plate and installed 4 springs. Something I did notice was on the throttle valve(302 in ATSG BOOK on pg 75)has 2 springs one smaller weak one and another 2 coil heavier one. Is this correct?
The HD2 shift kit instructions do not show anything beening done. I want to put it back stock so I can install my CK Performance shift kit. Anyone have any ideas? :confused:
Call Chris and talk to him..
If you have the TransGo installed, and Chris's kit replaces the springs the TG kit uses, no biggie.
Just put Chris's kit in. If it has some additional springs that don't get replaced by the Ck kit, then you might seek Chris's advice or gamble it.
Nothing wrong with the TG 200-4R HD kit, it is a redesigned kit from their original one that isn't liked here.
Very similar to other "preferred" kits.
HEY CHRIS
Can you answer this one? It is hard to get you on the phone.
Thanks,
Brian
my kit will correct this as it includes a new seperator plate ,springs ,servo ,boost valves ,pr spring accumulator spring etc.we will give you any additional info you may need to get working right the first time.see customer feedback on my home page and email me your phone number ,and ill call you tomorrow.
