TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
SignUp Now!Mark,
Not that familiar with the TT 6.0 but I've been reading up on it because I'm thinking about trying it out...
1-2 wot fuel looks like it is adding too much you can see where the correction factor goes to +19% fuel and your a/f drops below 10. If you trace 'blm' you can see the ecm add fuel to 153 which is when you hit your 10.8 target and stops adding fuel but the a/f continues to drop. So there may be some lag time in this arrangement. This may be because it is a rolling wot rather than a stage and go...again this is where I'm not familiar with the characteristics of the chip. Maybe set 1-2 a/f higher than 10.8 so that when the real load hits in 3rd you won't have that big rich dip.
3-4 wot fuel looks like it is able to recover to your target and maintains with minimal correction.
Trans shifts way low on the 2-3.
On a side note, I have an LC-1 and my a/f trace is jagged compared to yours. Did you add an analog ground from your LC-1 to the powerlogger analog block?
Thanks,
Mike
The correction is having to add too much fuel when the boost first comes up. Notice the how high the injector pulsewidth gets, but the a/f does not get richer. I would check two things: fuel pressure is rising at the same rate as boost, and that the alky is coming in fast enough. Whatever it is that is responding slowly catches up later and the correction has to pull it all back out.
It may be old but only has about 24,000 miles on it.With all the Walbro issues lately not real enthusiastic about putting a new one in. Might try the Denso one.
