- May 28, 2001
RFI ?
Electronic gurus.. Am installing a MSD DIS-4HO. Have a new set of MSD wires and new coil and module to go with. [Trying to eliminate an ign failure at max cyl pressure.]
Questions are:
1. What is the best insulator to put on the wire bundles to minimize problems?
I have the plastic "split wrap" matl, but don't think it will do much.
2. Will running the power wires directly to the batt via a route next to the headlite wiring on the core support, allow the wires to be "infected" w/ interference due to their close proximity to other bundles??
3. would adding a grnd from the box frame to the engine help?
4th and last, for those using this setup:
The directions only show hooking the 2 step to grnd thru a button.
Since the trans brake button actually breaks the power to the TB solenoid, how would a person take the 2 step to grnd, using the TB button?? [I'm thinking a relay, using TB power to close the relay and the switched side of the relay to take the 2 step to grnd.] YES/NO??
What effect may a relay have on the release time for the TB and 2 step?? My reaction times are BAD enuf as it is!!!!
THANKS for the help!
Questions are:
