right part number for arp head studs
4203's are SII studs.
123-4203 (12pt studs) are listed for stock head 109(86-87)
223-4203 (12 pt studs) are listed for stage2 14bolt head
bolts for stock heads on a 86-87block
123-3603 head bolts - high perf series -hex head
123-3703 head bolts -high perf series-12pt head
223-3703 head bolts -pro series - 12pt head
studs for stock heads on 86-87 block
123-4003 head studs - pro series - hex head
223-4203 head studs - pro series -12pt head
223-4204 are 12pt studs for champion alum heads on 86-87 block
While were on topic, anyone have the part numbers for the 84-85 blocks. Thanks!
for blocks (77-85) with stock heads
123-3601 head bolts high perf hex head
123-3701 head bolts high perf 12pt head
423-3601 stainless head bolts hex head
423-3701 stainles head bolts 12pt head
123-4001 head studs -pro series - hex nuts
123-4201 head studs - pro series - 12pt nuts
OK, whatever. Here's their site, noticed circled data.
It came out pretty small. If you can't read it, it says "Buick V6 Stage ll Champion head stud kit"
jegs online catalog needs some work
i use summit for looking up parts as they have an easier to navigate catalog and better descriptions , they also used to have the products install/tech manuals for download
arp studs
A while back I purchased a set of M&A stageIII heads for a stage motor. It was a complete kit, rockers,guide plates, etc. I would like to change out the head bolts tr studs. Do you have the part# for this combo? It's probably the same 14 bolt set like the champions? What's better-hex head or 12 point? thanks
