Where are you seeing the ripple and how much is the deviation? I can suggest several things that may cause it,may or may not be your issue.
- too much pre load on hyd lifters
- valve springs not stiff enough
- compressor surge due to the turbo being too large for your engine combo
Keep in mind...depending on how much the MAP is moving it will affect your tune, especially on the AE tables.
