turbobooster
- Nov 12, 2002
I'm beginning to install my RJC 3" exhaust finally! Well there's a straight bracket welded to the top of the muffler that slips into the factory bracket up top on the drivers side as you can see in the pics.... The bracket has a hole but not sure how it mounts ? Not sure if that bracket should even b there ? Any ideas as to how I'm suppose to use this Bracket with a hole in it ? Maybe someone has or can take a picture of how urs is mounted thanks
