Looks like you are pretty stock from your sig. So if you are going for pump gas levels/16ish psi or whatever the TT chip is set for then the wastegate rod to where you have to put about a 1/8" tension on it and then BC at its lowest setting go in from there a lil at a time.
Tune for WOT in 3rd for around 780ish with zero sustained KR and no more than 2-4 on the shift that goes away almost instantly!
Becareful and the car should be in perfect tune befor epounding it. if something pings hesistates etc then LIFT/STOP and get it repaired
