Dr.drivability
9 second wannabee
- Oct 1, 2005
Does the RJC plate cause issues in the higher horsepower cars??
SignUp Now!I know there are opinions out there!!!!Does the RJC plate cause issues in the higher horsepower cars??
I'm sure there's some people who would say at a certain performance level it becomes more of a restriction. Has any testing been done to prove it? Probably not. I'm not sure myself.
I have heard that it becomes a restriction. This was shown on a dyno.
Are we talking about in every level/application? in what level does it start to bigin to to become a restriction?? 12s, 11s, 10s, 9s??? On stage motors?? strokers?? big turbos???
Ask Jason C...who developed the plate...his car runs 9.6 with the plate...
It's hard to say with no scientific study but the way every one talks about mufflers, why would you voluntarily put a possible restriction plate. You would not put flow master muffs on the car would you?
Allot of thing need to be taken into consideration. IMO, once the pressure equilizes on both sides of the plate, does it still do what is claimed? I am sceptical. Keep in mind, the intake valves do not open all at once. That being said, if the intake is pressurized in boost, the next valve that opens will get the same amount of air as the rest regardless of the diversion plate.
I took mine off recently. Once I get to the track I will see if MPH/times improves.
On a side note, RJC makes great products for the Buick world. I don't think Jason would sell something he did not beleive in.
Pressure can only 'equalize' if no airflow is present.
Yes when air is flowing. If it were not it were defy the laws of physics. That's why you want a low restrictive intercooler with a low pressure drop (in addition to good cooling ability). Boost is a few psi higher before the intercooler vs after.So your saying 30psi boost in say the intercooler is not the same as 30psi boost in the intake? Hmmmm..
Yes. Whenever air/fluid changes direction there is a pressure drop so yes the plate is a restriction in a sense. But that restriction causes or prevents a lean condition in a few cylinders resulting in more power.Boost is a few psi higher before the intercooler vs after. Now don't you think that would play true to the intake/plenum with one of these plates?
