SignUp Now!Originally posted by elevensecgn
Just as a point of info, Jason Cramer broke into the 9s, (9.96 I believe) with his car at the Nats setting the first sub 10 sec ET and new record for TSM. BTW he was running a power plate![]()
Guess that should pretty much blow holes in any theorys that it may be a restriction![]()
Congrats Jason!!!
Dwight Hayden
Originally posted by Chris Taylor
I talked to Jason about the PP while I was at BG, and he is a nice guy. I was glad to see him running so fast with the PP. He did not try to sell me a PP, just answered my questions. Then I purchased one. Cool people at RJC Racing!!
Originally posted by Ormand
I don't see why Jace's times "blow holes in the theory that the plate is a restriction". It's not a theory, it's a fact. Look at the thing. It restricts the flow to the rear cylinders, preventing overboost, and allowing the front cylinders to do their "fair share". Without the restriction, the engine is limited by the max boost the number 5 and number 6 cylinders will stand, and the other four cylinders must get less boost than optimum. Without the plate, the boost to ALL cylinders must be "restricted" by boost control. By using the plate as a restriction, at the correct point in the flow path, the engine can use LESS restriction farther upstream. Here's an example, to make it easier to understand. Without the plate, knock limits boost to 17 pounds. Knock occurs on cylinder 6, which is lean, because of bad air flow distribution. Put in plate, and restrict air flow to cylinder 6. Increase boost to 19 pounds. More power! With the restriction, cylinder 6 gets same flow at 19 pounds it used to get at 17 pounds, but cylinders 1, 2, 3, etc., get more. Hope this helps.
Originally posted by strikeeagle
"Eyeball engineers" and "Internet Engineers."
<Two points:
<Where (oh, where) is the cylinder to cylinder, before and after,
I believe that has been on Jace's website for months.
<EGT data?
Unless someone is running six probes , one in each port, and recording the data both before and after, that would not be a conclusive test.
<You people who claim that there's no restriction because the sum of the open areas of the PP exceeds the open area of a given TB -please, GETTTTTTTTTTTT OFFFFFFFFFFFFFFFF ITTTTTTTTTTTTT!!!
If you have a given orfrice in a line (say 70 MM) and that is the smallest spot for air to pass through the system, then after it you have a number of areas that total MORE than that 70 MM ofrice, they are NOT going to restrict the airflow going through that line- period. They may "redirect it" but not restrict total airflow.
<On a separate note, Jason, congratulations to you on running a 9 - that's a helluva fast car!!!
Strikeagle, in your estimation, would Jace's car have ran faster if he had removed his power plate?? just curious-------
Dwight (you can lead a horse to water, but---) Hayden
Originally posted by Steve Wood
The proof is in the flow tests and in the pudd'n.
Two tenths on a base test car in front of thousands by Nick Micale at the Nats plus the testimonies of numerous satisfied users will suffice for all but the eyeball engineers including the ones that may have five years of experience repeate three times
Ok, 2 tenths? But that does not tell the whole story, what were the MPH and 60 FT's of these runs? Lets see where the 2 tenths came from, were these back to back under the same conditions, was anything else changed like FP? the numerous satisfied testimonies have ranged from "it feels faster"? to "it idles better" just curious what it really does.
