SignUp Now!I had a pushrod go right thru a rocker arm two years ago so I went the Sealed Power route with their arms and shafts.Originally posted by Fuelie600
Just purchased TA shafts after breaking off the #5 exhaust rocker. While changing over the rockers I noticed that rocker was begining to crack. This leads me to my original post, looking for a replacement. Brian
GM replacements are also marked with the R and L. A nice complement to the beefier shafts are the Loveridge shaft braces. They allow you to torque the retaining bolts onto a flat surface, serve as rocker arm guides, brace the shafts, and most of all they look cool.Originally posted by MSDGN
The stock original rockers I took off both my cars didn't have any right or left markings...I believe it's because the dimple for the pushrod is centered so it doesn't matter which way they go...as for the Sealed Power rockers the dimple is offset so they are marked 'R' and 'L'...not sure about replacement GM rockers...
