rocker shaft shims
1320n10
Does aneyone have a part # for the shims you can get at the ford dealer for the rocker shafts
Walt,
TA sells some kind of kit for the 455 Buick applications. Have you talked to these guys yet?
Neal
You can get stainless steel shim stock from Graingers and cut it to the size you want, punch a hole and you are done. The kit is $75.00 but you will have enough for life and could even sell some here to help others in the same boat if you wanted to recoup some.
