SignUp Now!What are the #'s I am looking for?What is tight and what is to loose?How much play should there be?
Anyone know of a link that has Pics or details instructions for instillation?
I did mine on the engine stand I removed the rear cam cover (freeze plug) put cam in with cam button (sets on the end of cam) bolted on timing cover with proper gasket and torque the timing cover to spec. In the rear of the block I used a magnetic base dial indicator on the rear of the cam. I then used a long screw driver to move the cam all the way to the front then all the way to the rear and measured this distance. stick the screwdriver through the openings in the valley between the heads. If distance is ok then it's set if there is too much thrust then add the the spacer shims (thin washers) onto the button untill your satisfied. Someone may have a better way but I looked at it and just did it. These instructions were not given to me just did it the way I saw fit. I don't think this could be done properly with engine still in car.
Here are the installation instructions:
1 Install timing cover gasket , install cover to set gasket crush. Use a minimum of 4 bolts on the
corners.
2 With a screwdriver catch a high lobe thru /between oil galley drain hole. ( not installing the
chain makes this a little easier)
3 Verify that the cam has end play movement .004-.008 is good . (A SLIGHT CAM SHIFT FOR & AFT )*
4 If step 3 has been verified to be ok , remove bolts and front cover and resume normal installation
of chain gears etc.
5 If step 3 does not reveal any end play install or remove shims to obtain correct play. ( The set contains
1-.030 2-.010 2-.005 shims )
6 Degree cam to card specs to insure maximum performance.
OK this is how I did it.ended up using one of the .30 and one .005 shims.
It gave me around .008. I like to use a little RTV around water ports so will add the other .005 shim for good measure.
